where does speed density sensor connect?
Old Jul 7, 2012 | 07:28 PM
phantomep's Avatar
Car: 1988 pontiac firebird trans am gta
Engine: 383
Im swapping my stock 350 for a 383 and switching to speed density instead of the MAF sensor. Ive got the wiring part of this figured out but i cant seem find anything on where the vacuum line connects to the manifold. If anyone can explain this to me or has any pictures of the where the line connects i would be grateful. thanks
Old Jul 7, 2012 | 11:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: where does speed density sensor connect?
the map sensor get its vacuum signal from the plenum. if this is a older maf plenum Do not t the vacuum signal dirll and tap the plenum. The 90-92 tpi plenums had three fitting on the rh side map, fuel pressure regulator and hvac.
Old Jul 7, 2012 | 11:28 PM
phantomep's Avatar
Engine: 383
Any idea on the size hole needed to be drilled?
Old Jul 8, 2012 | 11:10 AM
Engine: Lb9
Transmission: M20
The measurement to the center of the hole in relation to the fuel pressure regulator vacuum hole is 35mm over center to center. 55mm down from the top of the plenum and 20mm bottomof the plenum to center of hole. Gm 14082470 fitting for the map sensor. 1/4 npt hole.
Caspar
Jun 19, 2016 11:19 PM
deracer
Apr 11, 2016 12:04 AM
Steve78LT
Feb 24, 2016 12:15 AM
Keith5
Aug 27, 2015 04:37 PM
86Base
Aug 8, 2015 01:34 PM
