Odd stalling issue... Help!
Old Jul 8, 2012 | 09:44 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
88 305 tpi. I recently replaced the tps sensor and the iac . I did the whole aldl set up for the iac and set the tps to around 0.5 volts(had to use my friends test light that can read voltage cuz i didnt have a volt meter) it goes to around 4.3 on WOT , climbs smoothly when opening the throttle. I have a rip in the pcv hose i think( hose that runs from pass valve cover to throttle.) i taped it up to help the leak. I dont think the leak is big enough to cause my stalling. Fuel pressure seems fine. When i cold start the car it hunts until warmed and idles a teeny bit rough once warm. The car recently started stalling when i press the clutch down. Lets say im cruising at 2000 rpms and a red light happends. Il press tge clutch to coast to the light. The car goes down to about 6-500 rpm immediately and then slowly falls to zero... I dont want to take it to a shop. Because i need an exhaust asap. The passenger flange is leaking and its cut 3 feet after the cat.
Mark_ZZ3
May 24, 2018 01:02 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
