Tpi budget build question
Old Jul 15, 2012 | 12:44 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
Im doing a budget tpi build stock bottom end port headss n intake and lt4 hotcam.i want to find stock heads that flow the best and make the best power. I plain on getting them at a junkyard. Anyone know a casting or part number to some good heads to look for? I heard chevy used some heads that made 285 hp on tbi systems but not sure if its true.
Old Jul 15, 2012 | 06:47 PM
Car: 92 camaro RS
Re: Tpi budget build question
Ok so ive done some research. Found that the stock l98 iron heads with 1.94 valves are pretty nice after there ported and go with ****** valves. But I also just picked up a set of vortec 906 heads in a junkyard today. Not sure wat valve size they are or what valve size they can go to. Any suggestions on what woild make more power?
Old Jul 16, 2012 | 02:10 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Vortecs. But, will require a new base. So, you're gonna' spend money one way or another; reworking the stock heads or going with the Vortecs. Also, keep in mind, stock Vortecs are only good to about .450 lift, so you may even spend some money on springs and what not. Power/speed require money.
Old Jul 16, 2012 | 02:47 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Me personally would rather use the stock heads on TPI systems when on a budget build. Just have some porting/machining work and upgrade the cam & use 1.6 roller rockers & new bearings.
Old Jul 16, 2012 | 06:16 AM
Car: 92 camaro RS
If both heads are ported and have the same size valves then wats the difference between them? Not sure of the cc size on either of them tho. But if there is a differee how much hp difference would there be using vortecs over stock heads?
Old Jul 16, 2012 | 09:09 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Vortecs outflow the stockers by a good 30+cfm on the intake exhaust isnt much different. Better combustion chamber on the Vortec too.
Porting an L98 with stock valve size will only get you 220-230 if youre lucky. Exhausts pick up easily
Old Jul 16, 2012 | 11:07 AM
Car: 92 camaro RS
Well if I did go with stock l98 heads id go with 2.02 valves but I head u cant go tgat big on stock l98s.. Its more like 201 or something close tho
Old Jul 16, 2012 | 11:23 AM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
I am going with rebuilt L98 heads. I think you'll be surprised with how well the stock heads can perform after being rebuilt.
Old Jul 16, 2012 | 04:23 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Axle/Gears: D44 3.33 gears
Here's the flow numbers from my ported 113s with 2.00/1.56 valves
100 68 56
200 143 97
300 193 139
400 224 169
500 245 185
600 258 195
Old Jul 16, 2012 | 04:35 PM
Car: 92 camaro RS
The 113s are stock l98 heads?
Old Jul 17, 2012 | 12:04 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I had 2.02/1.60 valves installed in my 083 TPI (iron) heads.
Old Jul 19, 2012 | 09:51 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
113s were stock on 88-91 Vettes
Old Jul 20, 2012 | 09:09 AM
Axle/Gears: 4.11
If you go iron look into EQ cyl heads they have some decent stuff.
its an option
305 or 350?
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
