7730 Error codes
Old Jul 22, 2012 | 03:20 PM
89demon's Avatar
Car: 91 RS
Axle/Gears: Posi 3.73
7730 Error codes
I just swapped my 91 from a 5.7 tbi to a 7730 tpi and it is throwing a code but, I do not have a program to monitor that ECM......what is a good program to monitor the 7730 error codes and tune? I am also running into a problem....it is throwing that code which I'm not sure about yet but acting very peculiar...getting spark and my fuel rail has pressure but, will just turn over and over with only sputering once in a while. I finally did get her started but over 3000 rpm under load the power just dies and she will eventually stall.......and good luck getting her going again.
Old Jul 22, 2012 | 03:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 7730 Error codes
what codes do you get when you jumper the aldl connector ?
Old Jul 22, 2012 | 06:51 PM
89demon's Avatar
Car: 91 RS
only code 12
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
