Alternator/Crankcase Filtered air venilation tube issue
Old Jul 28, 2012 | 11:08 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I need some help from the guys who have the alternator on the passengerside. Can you provide me with a picture of your alternator? My issue is that the crankcase filtered air ventilation tube (In yellow highlighted picture below) is too long and hits the rear stud behind the alternator that charges the battery. So I wanted to verify if I have the wrong alternator due to the location of the connector and the battery recharging terminal stud behind the alternator.
Pictured directly below is the aluminum tube (numbered 58) that hits the stud that recharges the battery.
filteredvacuumenginetube.jpg?t=1343529820
Pictured below is my actual tube (with blue arrow) that hits the recharging stud (Yellow arrow). Does your alternator have the 2 wire connector (red arrow) in the same location as your altenator?
filteredvacuumenginetube-alternator.jpg?t=1343534810
If you can provide me with a picture of your setup, that would be great. Thanks guys.
Old Jul 29, 2012 | 03:26 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Alternator/Crankcase Filtered air venilation tube issue
your issue is the reman alternator rear case is clocked incorrect.
Old Jul 29, 2012 | 11:11 PM
Problem solved!!!! Thanks B!!!! Now, off to get a new alternator.
Old Jul 29, 2012 | 11:48 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Or you could undo a couple bolts and reclock it.
Old Jul 30, 2012 | 12:12 AM
Yup. Already reclocked it. But in the process of seperating the front of the alternator, the rear casing pulled away from the coil winding causing some internals to break. So I'm just gonna hit up a buddy at autozone and replace. I got lifetime warranty on that bad boy.
Old Jul 30, 2012 | 12:20 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Or use the 88-89-90ish molded 1 peice rubber hose that goes to the rear of the valve cover like the multi piece set up you have.
the 90ish-92 hose is shorter and goes the the front of the valve cover
Old Jul 30, 2012 | 12:29 AM
TTOP350. What's up man. I thought about getting that molded hose too. Tunerperformanc pointed that out and gave me the part number. But I got the aluminum multipiece tube so I figured I'd save $25 by staying with what I got. I actually thought about swapping out with the smaller alternator that is for the 87 and up, but then again, I would have to spend more money to get the 86-87 alternator connector conversion. So I really have nothing to lose, other than stopping at Autozone to replace the damaged big alternator.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
beast94
Aug 20, 2015 06:44 AM
mizz0313
Aug 12, 2015 06:45 AM
