Help plz. (Its more then one thing)
Old Aug 19, 2012 | 09:47 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
So like a noob i up graded my Inj to the next size up, and cut my cats off, and my fuel rail is leaking. I need to find parts to fix these problems. The Engine is the 305 Tpi. I want to up grade but i don't want to make any more mistakes. So i need to know where can i get a fuel rail, that is equal to the old one, good cat converts that are best for the new flow. The last thing how do i get my computer to know whats going on. Also smog pump has been removed. Any help advice is really appreciated.
Old Aug 19, 2012 | 10:38 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Help plz. (Its more then one thing)
If it wasn't leaking before you removed the injectors, you don't need a new fuel rail, you probably just pinched an "O" ring on installation. Put the proper 19lb injectors in, they are correct for a 305. Also, put cats back on, they are no restriction at all unless they're plugged.
Old Aug 19, 2012 | 10:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if it is the cross over tubes you can use this o-ring kit.
http://www.autozone.com/autozone/par...ier=79645_0_0_
Old Aug 20, 2012 | 01:08 PM
Facekill88's Avatar
Car: B4C
Transmission: Man 5
Thank you, and no its a TPI 305.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
