cant get.54 from new tps
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: cant get.54 from new tps
Has anyone ever popped the plug on your throttle adjustment screw.. When you tighten up the screws, Even if you can't get it down to that, You still might be ok.. what is it at WOT.. could be about 5.0 roughly...
Car: 1987 IROC-Z
I would say to try another. I was just curious if anyone played with you idle screw to begin with. There is a chance that it is defective.. The multimeter won't lie as long as it has calibrated. What was wrong with the old one?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If This is tuned port injection speed density you can use the older tpi tps and adjust it too 0.710VDC +/- 0.050VDC or 0.660VDC to 0.760VDC. The 90-92 tps does not have elongated holes for adjustment unlike 85-89 tpi it is not needed with the 1227730 ecm.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
the old one had a dead spot in it. i did the minium air reset an when i had all that done is when it checked tps. thats when i discovered the prob.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
If your 91 is OE stock, the TPS can read between .29 and .98 at closed throttle. It's not adjustable. The later(non adjustable TPS) OBDI GMs generally read .60-.90. As long as it's less than 1.0, the ECM won't have an issue with it. Minimum TPS is an adaptation of the ECM.
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
MikkoV
Sep 9, 2015 04:25 PM
