TPI with lt1 harness, ecm, sensors. will it work
Old Sep 15, 2012 | 07:57 AM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
I'm trying to find out if I were to take a 350 TPI engine, switch it with ecms, harness, and relevent sensors from an lt1 z28, would it run, thinking it was on an lt1 engine. what else would need to be done. thanks
Old Sep 15, 2012 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TPI with lt1 harness, ecm, sensors. will it work
Odds are you will need to place the opti-spark wheel into a distributor and mount the pickup for it. The LT1 ECMs likely require the proper opti signals.
RBob.
Old Sep 17, 2012 | 03:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Not sure what you are trying to achieve but if you were to go to that much trouble ,would be better to go to a LSX PCM
http://www.eficonnection.com/eficonnection/24x.aspx
Old Sep 18, 2012 | 01:16 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I'd have to agree. The only way I'd consider the LT1 system is if it was given to me and even then you still have to figure out how to get the opti hi-res and lo-res signals to the ECM to fire the correct injectors at the proper cam timing.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
355tpipickup
Aug 19, 2015 10:02 PM
jharrison5
Aug 19, 2015 05:53 PM
marcusaw
Aug 10, 2015 08:13 AM
