Okay posted in engine swap and tech info with no luck. I have an 85 Z28 305 TPI, 700r4 tranny, and posi rear. MAF setup with lockup converter etc...
Also have complete setup from a 1991 305 TPI, 700R4, also have rear but its not posi. I have all harness to the 91 except in the passenger compartment from the drivers firewall through the dash. I have the ECM harness all the way to the headlights.
What is needed to make this work in the 85? The ECM is bad in the 85 and it does have a hypertech chip in it a remanned ECM is only $50. Better to just run the 85 setup and switch tpi setups or is more needed?
