Fuel Pump Install Question
Old Oct 8, 2012 | 07:34 PM
Rich92 RS's Avatar
Car: 86 IROC-Z
Engine: 370 LQ9
Transmission: T56 Magnum
Installing the new fuel pump in the pickup assembly for a 92z L98 and ran into a little dilemma. The stock setup had this thing connecting the pickup tube to the fuel pump, and was wondering if I should re-use it or use the supplied rubber hose instead. Fuel pump kit is from Racetronix, and I emailed them aswell.
Old Oct 9, 2012 | 07:05 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Fuel Pump Install Question
I believe that it's called a pulsator. It's a rubberized chamber that I believe is there to absorb shock waves created by the injectors opening and closing in a batch. Last time I changed my pump I didn't put it in, next time I think I will just to see if it stops the fuel pressure gauge needle from vibrating like it does.
Old Oct 9, 2012 | 08:29 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, it is the pulsator. It's not needed, neoprene hose will do the job.
Old Oct 10, 2012 | 02:18 AM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
throw that out and use the hose, pulsators start to leak eventually and are useless
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
