Fuel senders...
Old Dec 10, 2012 | 10:52 AM
David 91RS/Z28's Avatar
Fuel senders...
Looking for comments on fuel sending units that you may have bought for your f-body. AC Delco, Dorman, Spectra, RightStuff... Quality? Is the Delco unit worth twice as much as the others?? Thanks!
Old Dec 10, 2012 | 04:50 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Fuel senders...
I put a spectra in my 85 and it fit fine. The fuel pump fit in fine and the gauge reads properly. No complaints here.
Old Dec 10, 2012 | 08:33 PM
Re: Fuel senders...
I'm really considering that one for the price! I read on their website that the materials have been ramped up for better corrosion resistance.
Old Dec 10, 2012 | 09:03 PM
LilSki's Avatar
Car: 85 Trans Am
Re: Fuel senders...
Here is a picture of it. It is next to the carb sending unit it replaced.
Old Dec 10, 2012 | 10:58 PM
Re: Fuel senders...
Good deal! I just can't see where the price of the Delco is justified. Nice swap btw!
Old Dec 11, 2012 | 06:25 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Fuel senders...
Did you follow a link to replace it? My gauge just stopped being accurate and I was wondering if removing the tank was the only option.
Old Dec 11, 2012 | 08:01 PM
LilSki's Avatar
Car: 85 Trans Am
Re: Fuel senders...
Not sure I follow but if the gauge reads wrong it can only be either the sending unit or the gauge. It would be easier to change the gauge to see if it fixes the problem. Otherwise it is the sending unit and you would have to drop the tank.
It could also be a grounding issue. If the sending unit is not grounded properly it could read wrong.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
