Gasket advice
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
Gasket advice
Took my car to a mechanic.. He said i had a manifold leak(intake) so i bought an intake gasket set and injectors and what not( if i was taking it out i might as well replace those too) so i took the car apart up to the intake manifold. One bolt snapped 2 t-40 torx bits. 2 of the bolts were able to be hand loosened without any t-40 used. Im guessing thats why im leaking... But what i wanted advice for,is should i keep trying to get the bolts loose and change the manifold gaskets? Or should i tighten them up hoping that fixes the leak.. And how could i get it out without snapping my torx bit? I used pb blaster too.. 305 tpi
HoosierinWA
Oct 7, 2015 10:15 AM
