TPI Removal
Old Feb 8, 2013 | 07:09 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
TPI Removal
I am trying to replace my head gaskets, I got the torx screws off the pelems(spelling) on the bottom of them but the whole intake wont budge. Am I missing anything and any tips on getting to the head gaskets?
Its a '91 305 TPI from a firebird trans am
Old Feb 8, 2013 | 08:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI Removal
Have to undo all the bolts holding the runners to the base and to the plenum including the two HIDDEN ones that go into the runners from the opposite side under the plenum
Once you have ALL the bolts out ( count them ) usually the plenum requires a smack with a soft hammer to break the gaskets loose
Red shows location of hidden bolts.
Old Feb 8, 2013 | 09:37 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: TPI Removal
Did you already drain your coolant ? If not your might want to pull your knock sensor on the bottom of the block to drain your block and drain your radiator before you pull the heads so you don't get alot of antifreeze on the pistons.
Factory RTV is usually used on the front and rear of the block to seal the Manifold Base to the Block.. Once you get the distrib out, the manifold, and both runners off you can see all the remaining bolts to include the hidden bolts. And yes, a dead blow hammer will usually be enough to shock the intake and loosen it up.
Old Feb 9, 2013 | 12:57 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: TPI Removal
Originally Posted by ibmtech
Once you get both runners off you can see all the remaining bolts to include the hidden bolts.
The hidden bolts I was referring to bolt the runners to the intake base
Old May 30, 2013 | 07:14 PM
Re: TPI Removal
Thanks, those hidden ones got me. Cylinder was full of coolent.....
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
