Looking for a little advice
Old Feb 17, 2013 | 08:19 PM
Redrag65's Avatar
1991 5.0 TPI-- car went from running perfect to hard to start (3-4 tries in a row) then once running, car wants to chug/sputter/slight backfire when in drive. idling is fine, revving engine in neutral is fine, in gear though, chugging a little then smooths out, sputters a little then smooths out. Any ideas on my issue?
Old Feb 17, 2013 | 08:28 PM
86irocdee's Avatar
Car: 86 IROC
Transmission: Automatic
Axle/Gears: Stock GM
Re: Looking for a little advice
sounds like your fuel pump may be going out. check fuel pressure.
Old Feb 17, 2013 | 08:31 PM
Redrag65's Avatar
Thank you, was hoping it wasn't connected to "injector issues."
Old Feb 17, 2013 | 08:38 PM
86irocdee's Avatar
Car: 86 IROC
NO IF IT WAS AN INJECTOR ISSUE IT WOULD RUN LIKE CRAP AT IDLE AND DRIVE FINE DUE TO THE FACT THAT MORE AIR IS ENTER THE ENGINE SO IT WILL COMPENSATE FOR THE EXTRA FUEL.
Old Feb 17, 2013 | 08:41 PM
Redrag65's Avatar
Thanks, it's smooth as silk at idle.
Old Feb 17, 2013 | 08:49 PM
86irocdee's Avatar
Car: 86 IROC
YOUR WELCOME LET ME KNOW HOW IT COMES OUT.
Old Feb 17, 2013 | 08:52 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Raise the hood at night; while running, look closely and check all the plug wires for visible sparking.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
