Milky Oil
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Milky Oil
What are the possible causes of milky oil? Yesterday I went to just check my oiland it was milky. Drained it out and kinda smelt like fuel, and seemed thin... (I think) Coolant is clean.
Checked my fuel pressure and it was 50 psi idle vacuum line off. So i figured maybe that can be the problem. So I tried lowering it with my crane AFPR but after more then enough 1/8 turns (cause there isnt much room) the pressure only dropped about 1 psi.... then i had to be somewhere and ran out of time...
any input/ opinions? all appreciated...
Engine: 5.7 L98
maybe it could be condensation? i move it about across the street and back everyday at work. short rides all winter...
Posted from Thirdgen.org App for Android
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Milky Oil
Usually a blown head gasket can mix oil and antifreeze. It would look like coffee with tons of creamer in it. IF that is the case drain that oil quickly becasue oil and antifreeze form a chemical that is like an acid. That acid will start eating the metal and causing pits in the cylider walls and even the crank. Hopefully it is something else. Describe more of the color or the "milky oil".
Engine: 5.7 L98
Re: Milky Oil
yeah kind of creamy like that, but the coolant level hasnt dropped a bit, and is as clean as can be....
Engine: 4++,350 & 305 CIs
Re: Milky Oil
If your worried about it, PSI check your coolant system, most parts stores have the tool 4 that.
Don't run it unless you can run it long enuff to burn that stuff out.
skinny z
Oct 5, 2015 06:23 PM
