coolant leak
Old Apr 1, 2013 | 02:16 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
coolant leak
Hi i popped my hood and noticed there was a puddle of coolant just sitting on the block under the throttle body, any ideas of what might be wrong to have caused this?
Old Apr 1, 2013 | 02:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: coolant leak
It's probably coming out of the thermostat housing.
It might also be coming from the throttle body.
I can't recall if the intake manifold bolt (where the puddle is) threads into the coolant passage....? It might be coming from there as well.
Old Apr 1, 2013 | 02:34 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Re: coolant leak
so how serious and and costly is something like this usually? cuz ive driven the car and the puddle doesnt seem to get lower or higher. here in awhile im gonna go soak it up with a rag and see if anymore takes its place.
Old Apr 1, 2013 | 08:34 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: coolant leak
Thermostat housing...almost guaranteed. Its about a 20 minute fix and a 10 dollar part (for a GOOD gasket). While your in there you should change out your thermostat if you have no idea how old it is. All told youll spend something like 25-30 bucks if you buy good stuff and you wont be leaking coolant anymore.
Old Apr 2, 2013 | 02:21 AM
GreenieG's Avatar
Car: 1985 IROC-Z
Re: coolant leak
well sounds like no sweat then, Im about 99.9 percent sure its the original thermo in there, i was looking at a 180 degree one from advanced auto for like 9 bucks.
Old Apr 2, 2013 | 03:53 PM
87rattler's Avatar
Car: 87 Iroc-Z28
Posted from Thirdgen.org App for Android
Old Apr 2, 2013 | 03:56 PM
87rattler's Avatar
Car: 87 Iroc-Z28
sorry...first post from phone. I had the J shaped hose leaking on mine. Connects the throttle body to the intake. IIRC.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
