52mm TB, Speed Density, Setting idle adjustment
Old Apr 14, 2013 | 11:20 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
Hi Folks
have a H/C/I 5.7SD TPI that I'm in the process of tuning.
i had the work done from a shop and they set the idle adjustment screw quite high to stop the car stalling to get me home. I've set it back all the way and its stalling on me when warm. No doubt because of the cam (xfi268) that wants to have a higher idle
I'm now also getting a TPS Low Code 22. The sensor is the original and am going to replace it for good measure
I wondered if anyone had any tips for setting the minimum idle speed on an SD TPI car. Most of what I've read seems to concern MAF cars
thanks
Old Apr 14, 2013 | 08:38 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 52mm TB, Speed Density, Setting idle adjustment
The setting procedure is the same.
You disable ECM control of the IAC , set min air (idle )with adjust screw then reconnect the IAC
If you have a cam that won't idle at the stock RPM then you are up sh*t creek without a new tune because the
stock ECM settings will keep trying to pull the idle down regardless what you do with the min air (idle ) screw trying to set a higher idle
Old Apr 15, 2013 | 04:07 PM
GTA1990's Avatar
Car: 1991 Trans Am
thanks, yep I have an EBL P4 that I've just set edited the idle tables for.
Just wanted to double check the mechancial idle adjustment process aswell.
regards
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Steve78LT
Feb 24, 2016 12:15 AM
perZ
Aug 15, 2015 01:17 PM
86Base
Aug 8, 2015 01:34 PM
