idle issue with the gas pedal?
Car: 91 Camaro RS
Engine: 305 TPI conversion.
when the car is running at idle, its kinda high at first and after warm up. I can get it to go down when I pull back on the gas pedal or push the throttle at the tb. is there a way to adjust the spring or loosen the cable a little? the only line attached to the tb is the throttle cable. I have no cruise control or auto transmission..
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: idle issue with the gas pedal?
There is no adjustment on the cable or spring unless you have a holley tb. Have you checked the throttle shaft for play ? It sounds like the wear in the throttle body is causing the blades no fully close.
Car: 91 Camaro RS
thanks though..
Car: 1990 Trans Am
Axle/Gears: Stock
If the throttle body's passages are all clear, you will need to replace the spring with a new one that's got more tention.
Got the same issue here. Lubrication does not help and at times I will have to pull the gas pedal back a little (while in idle) to get the RPM down.
1992 Trans Am
May 10, 2023 07:19 PM
