Runs great at idle, but can't get out of its own way in gear
My 88 Formula runs pretty good when it is idling, you can rev it up normally and everything. Once you put it in gear, it won't go over 2k rpms and pops and just runs like crap. Any suggestions? Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Runs great at idle, but can't get out of its own way in gear
Have you checked the fuel pressure or ohmed the injectors while the engine is warm ?
Car: 1988 bird
Engine: built 327, fi
Transmission: borgwarner wct5
Axle/Gears: factory 342 open diff for now
Sounds like you should check the mass air. Is it throwing any codes?
