injectors for LB9 305
Old Jul 18, 2013 | 08:23 AM
ash_cool's Avatar
Car: 1992 trans am
hey got another injector question for everyone. last week i posted i just got a procharger that was going on a new rebuilt 305 for really cheap. now plans have changed again. we are just going to put a bigger cam in the engine with a few mods like msd box, intake ported, headers, and under drive pulleys. now my question is will the stock 19lb injectors be ok with the camshaft im about to put in? it is a comp xr258hr12 or will i need 22lb injectors? im thinking 19lb will be ok from other threads on here but just want to make sure.
Old Jul 18, 2013 | 09:21 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: injectors for LB9 305
I have 19lbs injectors and make quite a bit of power with the not stock 305 I have
Old Jul 18, 2013 | 11:36 AM
ash_cool's Avatar
Car: 1992 trans am
thanks! 19lb it will be!
Old Jul 18, 2013 | 01:32 PM
If you have tuning ability I would get the bigger 22lbs and tune your engine for that in case one day you want to supercharge or what not. I was going to get 22lbs but I am going to swap my 305 for a bigger engine so 24's are going to be needed so I held off on the injectors.. For the record I have stock fuel pump and injectors.
Old Jul 18, 2013 | 04:48 PM
ash_cool's Avatar
Car: 1992 trans am
thanks hellz_wings think im going to run the stock fuel pump just cause i really dont want to change it. if 19lb injectors work on your set up then i know it will be good on mine. dont think this t/a is getting procharged? maybe my 89 gta?
Old May 2, 2015 | 11:19 AM
3rd-gen's 4life's Avatar
Car: 91 z28 camaro
Engine: 305 tpi
Axle/Gears: 410 posi
I have a 91 z28 305 tpi Camaro that I installed reman 4 hole bosh injectors that are 22lb @ 43.5 psi and are told my ecm will adjust to them and to achieve a 19lb flow rate I can adjust my reg to 39psi Maybe I should have asked questions on here first but Car runs ok not sure if it pulls any better or not just wanted someone to chime in on a recommended fuel pressure on my application or even if a tune can make 22's run good on my 305 tpi? any help would be great thanks in advance!
Old May 3, 2015 | 12:32 PM
southbay08's Avatar
19's in a 305 unless you're planning on making mod's that will increase your horsepower by a significant amount
gta90
Sep 15, 2015 04:00 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
