Venom FI Flow Rate?
Old Jul 20, 2013 | 09:41 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Venom FI Flow Rate?
I need the psi rating for my Venom 30lb fuel injectors (at what pressure are they rated at 30lb). The internet is a big blank, Summit has no answer, and Venom has given me two different outrageous answers (45-50psi & 77-81psi). The injectors did not come with any paperwork and their website has nothing. Does anyone have a flow sheet or know where there is one online or had their 30lb-ers tested?
Old Jul 22, 2013 | 01:17 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Re: Venom FI Flow Rate?
Called them and got a reasonable answer this time: 30lb @ 42psi
Old Jul 23, 2013 | 04:23 PM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
If they can't give you a straight answer, your other option would be to actually have them flow tested.
Old Jul 23, 2013 | 05:32 PM
southbay08's Avatar
what is the part number on the injector?
Old Jul 23, 2013 | 06:02 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Appreciate the help, but above in post #2 I got an answer. Thank you anyway.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
dusterbd
Sep 29, 2015 08:40 AM
