Code 33 & no start
Old Sep 9, 2013 | 11:08 AM
Crudsturbo's Avatar
Code 33 & no start
Cranks wont start will try to run if primed. Code 33 present. Im kind handy and I think Ive got it solved just need some info to make sure that this would cause a no start. Has 5 terminals A-E A is ground and it checks good. B is analog ground it also checks good. C is 5v refernce it checks at 5.05 and increases with WOT as intended. D is burn off signal and burnoff is clicking like intended with keyy off. E is 12v and it checks good. Broken wire inside MAF when you look inside.
Appears I have a bad MAF but before I drop the money for one just want to confirm it will cause a no start.
Old Sep 12, 2013 | 06:20 PM
Crudsturbo's Avatar
Re: Code 33 & no start
Bump....Anyone know at all?
Orr89RocZ
Apr 25, 2016 08:28 AM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
