help!!!
Car: 1988 Trans am GTA
Engine: 5.7 tpi
Transmission: auto
Axle/Gears: 3.27 posi
help!!!
hey guys im in need of help i did an intake swap my old one was 88 tpi new is 89 tpi i put new ford 24lb injectors in also with a chipped ecu no spark or injector pulse i have no other ideas ive been fighting this thing from the start! its on my 1988 trans am gta as far as i know it has vats the lil black thing on the key so i have no idea what it is....
i did however drive the car into the shop it was my DD for a while it ran good just wanted to delete the damn 9th injector so i switched to the 89 set up
tomorrow i will check the ICM also the purple wire going to the dist hopefully ill get some input ECM i have another idk if its good tho might try that to
