Fuel pump help!!!
Old May 16, 2014 | 12:35 AM
  #51
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
You should have a one or two cooling fan (depends on dual fans or single), and 1 Fuel pump relay. This is of course assuming a SD setup. Reference the diagram above to figure out which one is which. If any of the connectors look anything like that replace them. The help you seek has been provided here. Now its up to you to take the information provided and put it to good use.
Vetteoz has been more than helpful and I understand his frustration to this point because he has given you all the answers you need to figure it out. So use the diagrams. Get under the hood and figure out which one is which
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
