Tpi O2 sensor using headers
Old May 27, 2014 | 11:52 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
I have a BOSCH 4 wire universal O2 sensor and i need help with the wiring,
Black goes to the purple signal
Grey is the ground
White #1 goes to a 12v switched
White #2 Is where i need help, i read somewhere it goes to constant 12v source? would that drain the battery?
please help
Old May 28, 2014 | 10:46 PM
mjdavis68's Avatar
Re: Tpi O2 sensor using headers
checking back,,,,,,nothing guess i'll goggle research
Old May 28, 2014 | 11:01 PM
steveo_'s Avatar
its easy, the whites are the heater circuit. you ground one and +12v ign. sw the other
and like you said, grey goes to ground and black is signal.
i like to use a relay for power on heated o2 conversions
Old May 30, 2014 | 06:30 PM
Bigfoottpi11's Avatar
Grey is the ground
please help
Use the pink/blk wire at the EGR solenoid. IT works just fine there.
Old May 30, 2014 | 06:31 PM
You dont need a relay
Old May 30, 2014 | 10:40 PM
mjdavis68's Avatar
Thank you guys, and i will place a 10 amp inline fuse just in case
Linson
Oct 24, 2025 02:00 PM
Bradsaundry
Oct 7, 2015 04:35 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
