LT1 injectors
Old Jun 21, 2014 | 10:23 PM
Jokerandbarb's Avatar
LT1 injectors
I am looking for advice on the topic of shorter lt1 injectors being used on a 90 Tpi intake. Do I have to file down the posts for the fuel rails.? I installed the Holley 24lb injectors into the rails an used the locking clips. The injectors are slightly shorter than the stock 22 lb injectors I was using. The chip has already been re programmed for the 24lb injectors and the cam was also matched. I am adding the heated o2 sensor also. The throttle body is 52mm. Just looking for better running car. The motor swap went well but have a few issues.
New2Chevy
Sep 28, 2015 12:35 AM
webeeZ28
Sep 14, 2015 12:00 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
L0tuS
Sep 4, 2015 11:16 PM
