Fuel injector ohms
Old Jul 19, 2014 | 06:49 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Fuel injector ohms
Hey there guys I tested my injectors with my multimeter because my 92 L98 is not passing smog and has a slight hesitation when taking off. From my understanding all the injectors are supposed to test out to be around 16.5 ohms. My issue is the passenger side all tested to be 17, the two front driver sides tested 8.5 and the two rear driver side tested 11.5 ohms. What is the deal, does the driver side have mis matched injectors or something? I just bought the car and am having issues passing smog and have a slight hesitation taking off. What should I do? replace them?
Old Jul 19, 2014 | 09:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel injector ohms
Just luck of the draw. Each bank has it's own fuse for power. But all eight injectors are driven by the one driver in the ECM. Although each bank gets it's own wire from the ECM (exits on two pins).
Time to replace them and enjoy the better running engine.
RBob.
Old Jul 21, 2014 | 10:01 AM
southbay08's Avatar
Old Jul 21, 2014 | 10:02 AM
southbay08's Avatar
www.southbayfuelinjectors.com
516-442-4707
OOPS! sorry for the duplicate post.
Old Jul 23, 2014 | 03:26 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Replace them! And keep in mind that, checking injectors with an ohm meter means your checking the resistance... you can still have injectors fail mechanically and ohm fine.
Hope this helps!
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
