idle speed high
Old Aug 1, 2014 | 09:52 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
idle speed high
im stumped! I have rebuilt my throttle body (cleaned and all gaskets new) replaced the IAC and the TPS. adjusted the TPS per my FSM. and set the minimum idle air . yet when I plug the IAC back in, and start it. my idle speed is 1000 rpm??? now im not new to this. but I cant seem to get my idle speed in park to the 500-750 rpm requirement. everything is as it should be. any body have any thoughts?
Old Aug 1, 2014 | 10:50 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: idle speed high
Rusty...I'm in awe! Just something to check,but I'm sure you did.........nothings hanging up, blades closing fully???? Heck, you got me stumped.
Old Aug 1, 2014 | 11:39 AM
Car: 86 IROC
Engine: 5.0 TPI
Re: idle speed high
awwww, im no expert,just dedicated. and yes everythings as it should be. that is why it aint making sense.
Old Aug 2, 2014 | 10:43 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: idle speed high
Do you still have your ALDL jumped? I seem to remember that it may affect idle.....
Old Aug 2, 2014 | 11:07 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: idle speed high
What is minimum idle at?
Old Aug 2, 2014 | 02:25 PM
Car: 86 IROC
Engine: 5.0 TPI
Re: idle speed high
doing everything by the book ,in proper order. minimum idle is 600 rpm. UNTILL I hook up the ESC bypass wire and the IAC. restart it and then it idles at 1500 or so
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
