Not really sure?
Old Aug 13, 2014 | 08:53 PM
dmyruski's Avatar
Car: 92 Camaro Z28
Not really sure?
I have seen a lot of post about putting LED's in the instrument cluster and decided to do so. I replaced every (194) in my dash. Looked good, worked good. So I start the car to head home and as soon as it turns over the car runs at full throttle. First I thought I had the rug caught on the accelerator from working under there. But nope, that's not the case. It was running perfect before I installed the lights. Any suggestions???? 92 Z28 305TPI Manual Trans.
Old Aug 13, 2014 | 09:58 PM
dmyruski's Avatar
Car: 92 Camaro Z28
Re: Not really sure?
Also, I dont know if this has anything to do with it or if it is just coincidence, but I turned it on and off 3 or 4 times and now my key is stuck in the ignition. Luckily after it revs wide open it will drop to about 3500 and I had to pull the cable off the battery to shut off the car. Pretty sure a tumbler is stuck in the ignition but maybe it is tied into why it starts wide open and then runs at a very high idle. Any suggestions please help.
