Question: Oil pressure gauge not working
Old Sep 6, 2014 | 10:25 PM
motleykent's Avatar
Car: 1987 Chevrolet Camaro Iroc-Z
Transmission: B&M 700R4
Hi everyone,
I recently replaced the oil pressure sending unit on my 1987 Camaro 305 TPI, because my factory oil pressure gauge in the dash wasn't really working. I have an Auto Meter gauge pillar in my car, housing a second oil pressure gauge, which works perfectly fine (has separate sending unit). After replacing the sending unit for the dash gauge, the gauge still isn't working. The needle moves when I start the car, and drops to zero again when I shut it off, but while running it is just hovering above zero in the red. The guy at the parts store gave me a 60 psi unit, but I am wondering if the sender is the wrong one (note that my gauges are metric).
Has anyone had this issue before? I searched the threads but didn't find this scenario. Thanks.
Attached Thumbnails Question: Oil pressure gauge not working-2.jpg   Question: Oil pressure gauge not working-1.jpg   Question: Oil pressure gauge not working-3.jpg
Old Sep 6, 2014 | 10:29 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: Question: Oil pressure gauge not working
I had the same problem on my GTA. Replace the gauge. Its fairly simple and its a good excuse to upgrade the gauge cluster light bulbs to the 168 bulbs. They fit perfect and are a little brighter.
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
