'87 IROC with 5.7 TPI MAF issues
Old Jun 21, 2015 | 05:52 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey! quick synopsis..
Bought IROC, owner said MAF was bad, so they disconnected it to drive it.. I replaced it with a new one, ran great for 10 minutes.. After I shut it off for a day, I started it up, ran for a second, then shut right off..
I disconnected new MAF, runs fine..
Bad MAF? Bad wiring? Did something wrong?
Old Jun 21, 2015 | 11:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: '87 IROC with 5.7 TPI MAF issues
Any stored codes ? Iirc the non weather proof relays on the bulk head in 85-87 were inferior to the later weather proof ones. Small contacts, these often drew too much amperage and destroyed the relay to connecter and internal female connecters.
Old Jun 22, 2015 | 03:55 AM
Kevman's Avatar
Engine: 2004 LQ4
Just 12 followed by 34
Old Jun 22, 2015 | 11:47 AM
Engine: Lb9
Transmission: M20
http://chevythunder.com/maf_code_34.htm
Old Jun 22, 2015 | 01:55 PM
Kevman's Avatar
Engine: 2004 LQ4
So if you plug the MAF in and it doesn't run at all after resetting the codes... It's probably a bad unit?
Old Jun 23, 2015 | 02:16 PM
Kevman's Avatar
Engine: 2004 LQ4
Tried another unit, still won't run... Ordered two new relays for MAF power, and MAF burn off... Will post results.
Old Jun 24, 2015 | 09:43 PM
Kevman's Avatar
Engine: 2004 LQ4
It was the relays..
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
