Mass air flow or speed density
Old Aug 26, 2015 | 10:08 PM
Thornburg's Avatar
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Hello all,
So while looking through threads I found a thread about timing, and someone had asked if the guy had Mass Air Low or Speed Density style, I don't know the difference or how to tell the difference. I have a 1985 IROC with a 5.0 liter "F"
Pictures are worth 1000 words.....
Old Aug 27, 2015 | 07:35 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Mass air flow or speed density
Your 85 has a MAF.
"Mass Air Flow" sensor (85-89), typically called a MAF, or MAS for Mass Airflow Sensor measures the amount of air being drawn in to the engine. It is a fairly large housing (compared to a MAP) that is locate in the intake/aircleaner tract.
Picture here.
Or just here:
Speed Density (90-92) uses a MAP sensor = Manifold Absolute Pressure. This measures the pressure (vacuum) in the manifold and calculates how much air is flowing into the engine. It is mounted on the passenger side rear of the plenum:
Old Aug 27, 2015 | 08:28 PM
Thornburg's Avatar
Wow that's great!!! The pictures sure do help, I really do appreciate it.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
