ugh. please help. distributor.
Car: check
Engine: check
Transmission: check
Re: ugh. please help. distributor.
Need to pull the distributor, push out the roll pin retaining the gear and pull the shaft. There is a one-time-use clip that retains the shield. Under the shield is the pickup coil. A new one includes a new clip to retain it and the shield.
If that is a GM ICM I would get a new shaft (includes the star wheel) and a new pickup and continue to use that distributor. If it isn't a GM ICM add that to the list of items to replace.
Varnish build up on the shaft can make it difficult to remove. A carb gum cutter such as 2+2 makes short work of it.
RBob.
RBob.
89irocz355
Jun 6, 2016 10:52 AM
