Timing Issue?!?
Old Aug 12, 2016 | 08:43 PM
scoutcamper's Avatar
Timing Issue?!?
Hey everyone,
Finally got my 350 TPI in my 1965 C10 and got it running. Fixed my vacuum leaks, now im down to the final fixes before I can take it for a drive. I had not checked the timing at all, so I checked it and the timing was nearly 6 degress after top dead center. I shut the truck off, pulled the timing wire connector, started it back up, timed it to 6 degrees before top dead center, shut it off, reconnected the timing wire, restarted the truck, and now it is running like CRAP. It is backfiring through the intake and running very very rough.
Help???
Need any and all suggestions!!
Old Aug 12, 2016 | 10:17 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: Timing Issue?!?
You might be confused with before and after tdc...looking at 0 degrees, btdc is to the left or counter clockwise vs atdc is clockwise or going right...hope this was what you were needing and apologize if you already knew this just seems logical since it ran fine before it was adjusted
If that all checks out then reverify tdc with #1 cyl
Old Aug 13, 2016 | 11:46 AM
Re: Timing Issue?!?
Figured it out, sometimes it helps to have fuel in the gas tank :-P
dhobbs
Apr 25, 2016 08:01 AM
ARthe1
Mar 31, 2016 10:38 PM
Steve
Southern California Area
Mar 28, 2016 10:09 PM
SRKLEGIN
Mar 27, 2016 05:57 PM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
