Well guys....Help me spend money.
Old Dec 27, 2001 | 01:16 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I have the LT4 hotcam, and i'll have the springs, 1.6 rr's, along with the headers shortly. I also will be getting the LT1 intake shortly. Now here's the part i've been tossing around. I'll have a 1,000 to play with soon enough, and i dunno howto spend it. Should i get heads, or rearend gears or rebuild the block? Any other idea's where the money should go? And no, i will not be donating
Old Dec 27, 2001 | 05:05 PM
IROCKER's Avatar
Definately gears and a AFPR if you don't already have one. Both of these things I'm hoping to install in my car over the winter. And how bout some suspension brake upgrades? Good luck.
Old Dec 27, 2001 | 05:21 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Definitely freshen the bottom end, heads would be next!!
Old Dec 27, 2001 | 11:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I'd go with gears.
It should cost around $200 for the gears and $100 or so for all the bearings which I would replace if I were you.
Install can range from $150-350. Just make sure you get them done at a place that knows what they are doing.
My brother went through 4 sets of gears in 4 months in his 96 T/A.
Could have almost bought a built up Moser 12bolt with 3.73 gears for what we paid in gears and installs. It's a long, long story. Just make sure that they will warranty the gear install & buy you new gears if they break due to incorrect installation.
Just my $.02
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
