IROC won't start
Old Aug 27, 2016 | 09:56 AM
G28's Avatar
G28
IROC won't start
Found this disconnected by the battery. What is this and where does it go? Could it be the reason why the car won't start?
I've replaced the fuel filter and fuel pump relay....just checking anything else I can before I decide to replace the fuel pump...car cranks but won't fire....it'll fire with starting fluid.
Old Aug 29, 2016 | 06:26 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: IROC won't start
If it fires on ether then u have a fuel problem someone definitely added or repaired wiring there though i would pull the cap off the shrader valve and see if fuel sprays out if so then u know pump is good do you hear fuel pump when u turn key on
Old Aug 29, 2016 | 07:16 PM
G28's Avatar
G28
I can't hear the fuel pump kick on. Fuel doesn't squirt out of the schrader valve. I've tried pressing it down while someone cranked the car over and nothing....no fuel came out of the valve.
Old Sep 4, 2016 | 02:12 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
That definitely is add-on stuff and probably not related to your problem. However, I would attempt to trace it and determine what those connections are used for.
Is there any aftermarket electronics on your car? Any evidence of hacked wiring?
You can temporarily by-pass the factory fuel pump circuit in order to test/run the fuel pump.
Bowtieman1970
Aug 17, 2016 02:50 AM
gt4373
Mar 31, 2016 11:10 PM
Joseph Andres
Aftermarket Product Review
May 7, 2001 06:08 PM
D-Rock'87GTA
Mar 7, 2001 12:49 PM
Auggie
Nov 2, 2000 02:17 PM
