Wrong cylinder heads?
Old Dec 5, 2016 | 02:04 PM
83 Gman's Avatar
Hi
I have a 1986 350 engine I bought that came with Edelbrock Performer RPM heads, 70 cc camber and 170 cc intake runner length. Could be wrong on the runner length size.
It has the stock TPI.
Flat top TRW 10:1 pistons.
My question is:
Are the heads over kill for the intake?
I am using Hooker full length headers w/ 1 5/8" primaries.
Cam is a Lunati P/N 60101
Old Dec 5, 2016 | 07:00 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: Wrong cylinder heads?
Originally Posted by 83 Gman
Hi
My question is:
Yes, heads are overkill for the intake. but not to worry. They are not hurting anything. 60101 cam is 112 LSA, .454-468 I/E lift and 213/219 I/E duration at .050 for 1000 - 5500 RPM. That's right in the sweet spot of the stock TPI and you likely run out of air before 5500. Granted it will run better at higher RPMs with larger intake/runners, but likely at the sacrifice of low-end torque. Everything is a torque/HP/RPM balance. If it ain't broke, don't fix it.
Old Dec 27, 2016 | 03:30 PM
83 Gman's Avatar
Thanks for your answer.
Sorry it took so long to reply.
Old Dec 28, 2016 | 04:11 AM
Pat Hall's Avatar
Yeah, what 84Elky said is spot-on. The fact that your heads are only a 170cc runner volume, you should be just fine. It'd be a different story if they were like the more common 195cc runner volume.
