3.27 Gears HSR?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Re: 3.27 Gears HSR?
Wouldn't be that bad with say a 2,800rpm-3,000rpm stall converter depending on what cam you are using. 3.73 gears may be a better fit.
The HSR will shift the power band up so you will be making good power in the 5,000rpm-6,000rpm. Steeper gears will help you get in to that power band faster. The higher stall will help you stay in the power band while you are accelerating.
Car: 1988 camaro
Engine: 383
Re: 3.27 Gears HSR?
Thanks, Just getting some ideas. My gta has a rod knock and i have a 383 with brodix ik200 heads with a crower 00468 cam all done sitting on a stand. But i dont want the stock setup choking it. Thanks again..
