305 not starting
Old Dec 30, 2016 | 12:30 PM
metalhead1's Avatar
305 not starting
Fact is that my 91 Z has been sitting in garage for a few years without running. One of those "just never got around to it" things. Paying for it now.
Anyways, new battery, engine turns and runs briefly with starter fluid. great.
I knew gas was bad so I removed sending unit/pump (very corroded), sucked out all old stuff, replaced pump/unit with new. Also replaced filter and blew out fuel line with air. Added new gas.
Still no start. I have fuel pressure at rail. You think rail and/or injectors are clogged? That's my guess. Can they be cleaned or do I replace injectors?
Also, i see many types/ratings of injectors. Any help with this? My plan for now is to keep it stock.
Thanks!
Old Dec 30, 2016 | 03:03 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: 305 not starting
Do you have spark? I'd check there first.
Could also be moisture accumulated in the distributor cap, especially when you say it's sat for a long time could be a problem. Take the cap off, lightly spray some WD-40 in the cap, shake out the excess, then put the cap back on, and see if it at least tries to start.
Old Dec 30, 2016 | 03:36 PM
metalhead1's Avatar
I'm guessing it has spark because it wants to run using starter fluid. Perhaps a weak spark from what you said. I could check that but still thinking injectors. Didn't know if they get clogged from sitting.
Old Dec 31, 2016 | 10:37 AM
southbay08's Avatar
Thanks!
If the car was sitting for a few years there is a good chance that the injectors are clogged. It will cost just as much have them cleaned as it would to get a replacement set. If you're interested give us a call and we'll be happy to help you. Make sure that your entire fuel system is cleaned out...tank as well
Old Dec 31, 2016 | 10:41 AM
metalhead1's Avatar
I really don't have a problem replacing them, other than the difficulty in doing it. I want to make sure I get the right ones, as I see there are many types.
Old Dec 31, 2016 | 12:06 PM
southbay08's Avatar
you need the 19lb bosch
Old Jan 2, 2017 | 03:05 PM
metalhead1's Avatar
I ordered a set through the ebay site. Also going to change out EGR and Fuel regulator since I'm that far into it. Plenum gasket too.
