89 Camaro TPI Wiring
Old Jan 3, 2017 | 05:42 AM
91rs1022's Avatar
Car: 89 Camaro RS
Transmission: 5 Speed
I have a 89 Camaro I'm doing a V6 to V8 swap. I got a used TPI harness from a 89 Camaro. I installed it yesterday and I seem to be missing the alternator charge wire. How is that ran? I also have 2 connectors on the drivers side that have no connection point. Both are like a # 10 or # 12 wire one is red one is orange. Thanks for the help
Old Jan 3, 2017 | 06:41 AM
91rs1022's Avatar
Car: 89 Camaro RS
Re: 89 Camaro TPI Wiring
I think I might have been sold a Firebird harness, but can't confirm
Old Jan 3, 2017 | 12:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If the harness you have installed now is from a bird. I think the orange wire goes from the battery + to the oil pressure sensor. You might try ohming it to make sure that's correct.
Old Jan 3, 2017 | 12:08 PM
Engine: Lb9
Transmission: M20
The red I think goes to the fan relay and hooks to bat + but I'd ohm it first.
Old Jan 3, 2017 | 06:33 PM
91rs1022's Avatar
Car: 89 Camaro RS
Awesome, I'll double check with a meter. I assumed it was either the fuel pump or ecm since the one is fused with a 20 amp fuse and the other is just a fan control. Once it gets above freezing I'll double check. It was supposed to be a 89 Camaro harness but I think it got a firebird harness. Those 2 power supplies are on the drivers side and my canister purge wire is on the passenger side. Totally backwards but I'll make it work. Thanks for the help
