TBI to TPI conversion
Old Mar 6, 2017 | 10:27 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
Alright, it's been a while since I've done anything to my car. I need assistance on this conversion. I need a lost of all things needed to complete this project and get it running.
Engine has been built, 305ci bored .030, mild cam, port and polished heads. I have a (1227165) MAF TPI system w/jet performance chip 18813, wire harness, intake manifold, runners, plenum, it was originally a TBI system.
What else will I need to fully complete this project?
IF there's a list of parts that I will need please advise. It will be greatly appreciated. Or maybe a link to a thread where all this is listed. I found a great detail list for a speed density TPI system, but I'm not sure if those parts are equivalent to the MAF TPI system.
Old Mar 8, 2017 | 09:52 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: TBI to TPI conversion
Just a high pressure fuel pump should be it. Do you know what year your harness is for?
I believe there is a tech article on installing TPI on non-tpi cars
Old Mar 8, 2017 | 11:07 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Off the top of my head :Intake gaskets, TPI gasket set, Throttle body, TPI Throttle cable, TPI fuel lines, fuel injectors ( if you already have them they may need to be cleaned if they have been setting any length of time) MAF Sensor, TPI air cleaner setup.. and a bunch of other little things that you haven't thought about...
Old Mar 9, 2017 | 05:45 PM
Car: IROC
Engine: 383
Axle/Gears: 3.45
Not quite sure it goes with ECM 1227165, from what I've read is that, this is a 86-89 System. I'm actually looking for a clear pinout schematic to make a new harness or eliminate things that I'm not using. Like for instance I have T-5 transmission so I would eliminate the A/T wires, A/C and power Steering as well as. I'm trying to keep it pretty simple.
Old Mar 12, 2017 | 10:19 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Not sure what year harness you have but here lists the c110 and c207 for both 1987 and 1989. Big difference on an 89 as it doesn't have a cold start injector http://www.austinthirdgen.org/?pid=19 Not hard to remove a/t wiring and add m/t reverse wiring also
