ford motorsport 42lb green top noise
Old Mar 30, 2017 | 05:08 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
so i took my procharger off to send out for repair and man it sounds like my valves aren't adjusted but its the tapping from the injectors... anyone else notice this? they seem loud
Old Mar 31, 2017 | 11:57 AM
GeneralDisorder's Avatar
Re: ford motorsport 42lb green top noise
Yes my Bosch injectors are very loud. It's because the TPI is bank fired and all four injectors on each bank turn on and off in unison making them seem much louder than they would be on a sequential injection system.
Rick
Old Apr 1, 2017 | 07:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Our TPI cars are batch fire, all eight fire together.
As for the noise, make sure that the injector bodies are not in contact with the base. They need to 'float' on the o-rings.
RBob.
