Afr lean at idle and good at wot?????
Old Apr 22, 2017 | 04:14 PM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
i hooked up an innovate wideband 02 sensor and getting very lean 22 during idle at 1500 rpm in driveway
During wot driving 3-5000 rpm afr 10-11
at stop light at 1500 rpm 15-16
when i calibrate the innovate it shows 22.4 in open air. I don't think it is possible to have 22 afr during idle in drive way????
any thoughts
Old Apr 22, 2017 | 04:22 PM
Re: Afr lean at idle and good at wot?????
Driving at 1500-2000 rpm afr is 14.5-15
engine is 383 with 30# injectors and chip from member at thirdgen
Old Apr 22, 2017 | 04:55 PM
Twin_Turbo's Avatar
1500 idle is too high anyway and 10 to 11 wot too fat
Old Apr 22, 2017 | 05:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If those readings are right you need to datalog for your tuner to correct the maf tables.
Old Apr 22, 2017 | 05:42 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Check your fuel trims.
Old Apr 22, 2017 | 09:00 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Could be an exhaust leak. Where is the sensor installed and how good is the weld?
Old Apr 24, 2017 | 06:42 AM
tuning is a problem for me at this point in time wrt to new program or chip. I know I can get a better tune
i can play with my fuel and timing for now
vanilla ice
o2 bung is welded in my cat bypass pipe the weld looks solid
is the lean lean only presenting itself at idle because of my cam overlap 114 for a X-r 269(by memory)?
i want to drive the car but worried about this lean at idle causing damage.....
