IS MY CAR GONNA START ON FACTORY TUNE??
Car: 87 IROC
Transmission: auto
So my project this weekend is to try and start the 383 in the 91. I don't expect much out of it, but I just wanna get it to run and drive for now. I already talked to a well known member here about tuning it. The plan is to throw the injectors in from the l98 in the IROC, and put a speed density l98 chip in the ecm. The 383 has a super ram and a comp cams xfi 280 in it. Will it at least start and run? Or will that cam reek havoc with the speed density?? Opinions please.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: IS MY CAR GONNA START ON FACTORY TUNE??
Car: 87 IROC
Transmission: auto
That's why I wanna swap the injectors out. It is a pain with the super ram, but I don't wanna wash the cylinders with the 30lb ones in there now. I figured if I at least put stock injectors in it might run poorly, but at least it won't damage the motor, correct?? Or should I put it on a trailer and haul it to Pittsburgh before I do anything and get it set up for the injectors currently in there? That's the reason I'm throwing this out for input...
Engine: Lb9
Transmission: M20
The stock injectors might make it run too lean.
