Fuel line fittings
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Fuel line fittings
So mounted on the drivers side accessory bracket, above the power steering pump, there are 2 fuel line extensions. The ends of them are those saginaw type of lines. But what's the type of the female fitting (on the braided hose) called?
And these would be inlet/outlet at the fuel filter I believe?
https://www.summitracing.com/parts/s...009b/overview/
Re: Fuel line fittings
It won't without an adapter. All the TPI hardline fittings are going to be the metric O-ring type. If you want to use AN hoses, you need adapters.
Check out this thread - https://www.thirdgen.org/forums/alte...-fittings.html or just Google "TPI fuel line adapter".
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Fragola 491970 and 491971
491963 and earl's 9894DBJERL
Engine: Lb9
Transmission: M20
The return is the 5/16 line iirc 14mm thread supply is 3/8 16mm
