Wires for the smog pump?
Old Jun 17, 2017 | 05:26 PM
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Im in the process of taking the smog equipment out of my GTA, any idea what i do with these 2 wires in the Black box above the passenger side value cover?
Old Jun 17, 2017 | 07:21 PM
GeneralDisorder's Avatar
Re: Wires for the smog pump?
I just tucked them out of the way. You could lop them off, heat shrink the ends, push them into the main split loom and tape it up.
If you are going to eliminate ALL the emissions you will need an EGR block off plate and a custom PROM chip. If you are just doing the smog pump then the computer won't care. You can get the pump delete pulley on Amazon.
GD
