Which sensors are these?
Old Jul 27, 2017 | 05:27 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
While my L98 is out of my 1991 trans am, I would like to replace the sensors that will be difficult to reach once it's reinstalled. On the lower side of the motor, there appear to be four sensors: 2 temp sensors, a knock sensor, and an oil switch/sensor. Is this correct? Are there any sensors I'm missing?
Old Jul 27, 2017 | 05:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Which sensors are these?
You forgot map, the cts and iat are the same just different locations.
Old Jul 27, 2017 | 10:03 PM
wgripp's Avatar
Map = mass air, correct? CTS = coolant temp sensor. What's IAT? Is there a diagram of where all the different sensors go?
Old Jul 27, 2017 | 11:00 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
IAT=intake air temperature. Underside of upper plenum close to fuel pressure regulator on tpi cars. I believe I read some years have them in the air filter duct or maybe folks modify and move them there. I'm not educated on tbi location.
Old Jul 28, 2017 | 02:13 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
MAP = Manifold Absolute Pressure,
MAF = Mass Air Flow
Old Jul 28, 2017 | 04:00 PM
Engine: Lb9
Transmission: M20
if you have a 91 it's map (speed density).
