EGR valve cleaning
Old Oct 23, 2017 | 12:01 AM
faisal's Avatar
EGR valve cleaning
Hi all, I'm about to remove and clean my 91 TPI EGR valve , is there any reset like pressure test OR release I need to do before re-install .. Thank you ..
Old Oct 24, 2017 | 10:42 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR valve cleaning
Just watch the chemicals your using. Keep them away from the diaphragm.
This might destroy it. You can push up on the diaphragm to move the pintle up to clean the passage. Normally there is minimal amounts of carbon buildup.
Old Oct 24, 2017 | 11:39 AM
faisal's Avatar
Thanx for the reply , I meant to the engine after install it back or getting new one .. any reset should be done before putting parts back ?
Old Oct 24, 2017 | 12:52 PM
Engine: Lb9
Transmission: M20
No resets needed
