pushrod length
Old Oct 29, 2017 | 12:56 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
pushrod length
going with lt4 hotcam, edelbrock vortec etec 170 heads, what length pushrods do i need
Old Oct 29, 2017 | 03:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: pushrod length
Unfortunately there could be a fair amount of variance that wouldn't allow a cut and dry answer. The stock length should work. The only way to be sure is to buy an adjustable length pushrod tool and check. With my Trick Flow heads the stock lengths worked but with my AFR heads I had to switch to a different length.
Old Oct 29, 2017 | 04:29 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: pushrod length
If it's not all stock, then you've got to measure. Take a look at a short thread I had started when I was measuring for mine. There's good input in that thread on how to measure accurately.
https://www.thirdgen.org/forums/tech...od-length.html
Old Oct 31, 2017 | 08:10 AM
Abubaca's Avatar
Re: pushrod length
definitely measure. Adjustable pushrod and checker springs are cheap. I Borrowed a spring compressor from a buddy but I bet you could rent one from Advance or one of the parts places.
Old Oct 31, 2017 | 10:20 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: pushrod length
Checker springs are good. another idea for them is 1/8 scale RC car shock springs if you know someone that runs RC cars can just borrow them to check it...
antman89iroc
Apr 10, 2017 07:06 AM
Jorlain
Oct 30, 2016 02:38 PM
JCS94
Brakes
Oct 16, 2016 06:07 PM
AlkyIROC
Oct 3, 2016 08:33 PM
UltRoadWarrior9
Sep 23, 2016 06:38 PM
