FUEL LINES
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
FUEL LINES
ok im gonna be installing the holley stealth ram on to my trans am this winter..i don't really like how u have to run the fuel lines from the factory lines.my question is if I cut the fuel lines back under the brake booster is there a union fitting or a compression fitting that will work with a an fitting??
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: FUEL LINES
You can do a an flare and use a tube nut. Iirc an6 and an4 for the return.
https://www.summitracing.com/parts/fra-481804
https://www.summitracing.com/parts/fra-481904
Iirc an is 37 degrees
https://www.summitracing.com/parts/sum-900311
https://www.summitracing.com/parts/fra-481806
https://www.summitracing.com/parts/fra-481906
The feed line is 3/8 return 5/16
Engine: Lb9
Transmission: M20
Re: FUEL LINES
The return might be a an-5 or 5/16" JIC SS Tube Nut
https://www.fastenal.com/products;jsessionid=G4UUWiroeRmmaPyvTT3xfg1E.443d7b2e-1555-3602-a586-c0d73327934b?r=~%7Cmanufacturer:%5E%22Fastenal%20Approved%20Vendor%22$%7C~
https://images.search.yahoo.com/imag...K9&fr2=piv-web
http://www.jegs.com/i/Earls/361/991907/10002/-1
